Displays the protocol filtering configuration and status.
| port_list | Displays port list, separated by a comma ( , )or dash ( - ). |
| all | Displays all ports. |
| detail | Displays detailed configuration and status. |
Displays all protocol filters.
Use this command to display the protocol filtering configuration and status.
The following example displays the filtering configuration and status for ports 1-4:
# show ports 1-4 protocol filter
Port Protocol Destination Protocol Id Field Field Field Packets
# Filter Name Address Type Value Offset Value Mask Filtered
1 my_list 01:80:C2:00:00:02 etype 0x8902 14 03:04 FF:FF 2300
01:80:C2:00:00:00 snap 0x4041 5000
01:80:C2:00:00:00 snap 0x4041 16 01:02> FF:FF> 5000
2 lacp 01:80:C2:00:00:02 etype 0x8902 14 01 FF 3200
3 (none)
4 (none)
> indicates that the value was truncated to the column size in the output.Use the
“detail” option to see the complete value.
The following example displays output for the show ports protocol filter detail command:
show ports 1-4 protocol filter detail
Port 1
Protocol Filter Name: my_list
Destination Address : 01:80:C2:00:00:02
Protocol Id Type : etype
Protocol Id Value : 0x8902
Field Offset : 14
Field Value : 03:04
Field Mask : FF:FF
Packets Filtered : 2300
Destination Address : 01:80:C2:00:00:00
Protocol Id Type : snap
Protocol Id Value : 0x4041
Field Offset : 16
Field Value : 01:02:03:04
Field Mask : FF:FF:FF:FF
Packets Filtered : 5000
Field Offset :
Field Value :
Field Mask :
Port 2
Protocol Filter Name: lacp
Field Offset : 14
Field Value : 01
Field Mask : FF
Packets Filtered : 3200
Port 3
Protocol Filter Name: (none)
Port 4 Protocol Filter Name: (none)
This command was first available in ExtremeXOS 15.5.
